Each time I tried to read an SQL database and include a where clause statement in the reader the FME was fails to do so, even when I tested the statement it was running successfully see below.
Does any one know how could id solve this error?
The error as the following:
2018-11-22 16:31:29| 1.8| 0.0|INFORM|FME API version of module 'VertexCreatorFactory' matches current internal version (3.8 20180604)
2018-11-22 16:31:30| 1.9| 0.1|ERROR |Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement. Query Text `SELECT [BBSId], [ID], [Entity/Observation], [Observation Date], [Observation Type], [Severity of Observation], [Performed By], [EmployeeID], [Person Observed], [CONT_SVC_PROVIDER], [Not Listed], [CONT_SVC_PROVIDER_Name], [Name_Third_P_Inv], [Group Type], [Safe], [At Risk], [Description], [Longitude], [Latitude], [Location], [OrgAxisId], [Reference], [Workplace Activity], [Offline_CONT_SVC_PROVIDER], [Behaviours], [Company], [Platform], [Created on], [Created by], [Last Modified on], [Last Modified by], [AtRisk Corrected], [RelatedAction], [OpenAction], [Actions], [Open Actions], [Completed Actions], [Overdue Actions], [IsDeleted] FROM Aconex.[vEnablonBBSObs] WHERE SELECT *
FROM Aconex.vEnablonBBSObs
WHERE "Observation Date" > '2017-06-30''. Provider error `(-2147217900) Incorrect syntax near the keyword 'SELECT'.'
2018-11-22 16:31:30| 1.9| 0.0|INFORM|Microsoft SQL Server Non-Spatial Reader: Closing `eODS' . Read operation complete
2018-11-22 16:31:30| 1.9| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2018-11-22 16:31:30| 1.9| 0.0|INFORM|Translation FAILED with 2 error(s) and 0 warning(s) (0 feature(s) output)
2018-11-22 16:31:30| 1.9| 0.0|INFORM|FME Session Duration: 5.6 seconds. (CPU: 1.1s user, 0.6s system)
2018-11-22 16:31:30| 1.9| 0.0|INFORM|END - ProcessID: 9312, peak process memory usage: 683540 kB, current process memory usage: 683540 kB
Program Terminating
Translation FAILED.
Thanks,
Rawan
