Writing a feature with multiple geometries
  • Jun 25, 2013 8:50 AM UTC
  • 38 views
   My input feature has 2 attribute (One numeric ID, Geom Point geometry). I found 2 map geometries(Multiline) for ID in db. So after fetching, sql executor generates 2 features as (ID,GEOM,MAP1)  and (ID,GEOM,Map2).
I used aggregator assuming that it will return me (ID,GEOM,(MAP1+MAP2))
and then trying to write into database but failing.
Please suggest me how to approach this problem?
Subrat
Best answer by takashi
It's difficult to suppose the failure reason. Could you post the log messages about the failure?
Takashi
  • Jun 25, 2013 10:26 AM UTC
Takashi
