Writer output folder
  • Jun 15, 2014 3:28 PM UTC
  • 11 replies
  • 225 views
Hello,
 I am new to FME, recently started to work on FME Desktop 2014. I am looking to convert any format to CSV. My requirement is to deposite output CSV to same input folder.
e.g. If user selects c:\\temp\\test.shp then test.csv should be written to c:\\temp\\folder.
Currently I am able to convert the file but I am not able to set output path same as input path.
I am not sure how to achieve this.Any pointers in the right direction will be appreciated.
Regards,
john
gio
Forum|alt.badge.img+15
  • Jun 16, 2014 9:03 AM UTC
Your input shapefiles have a parameter $(SourceDataset_SHAPE) (see navigator panel)
If u create a attribute directory_out or something after parsing it from this parameter.
Or you can use a driectory and filename reader. To  do samish.
  • Jun 16, 2014 12:37 PM UTC
Thanks for your reply.
I can create directory_out attribute but how to assign it to DestDataset macro so that it will create csv in that folder.
gio
  • Jun 16, 2014 1:39 PM UTC
Ah, i see.
create a scripted parameter (in my picture $out).
In the stringeditor of this scripted parameter you can make a link to the Sourcedataset.
You can extract the path in this editor, using regularexpression.
Then edit the parameter of the DestDataset_SHAPE and link it to the created parameter
  • Jun 16, 2014 1:45 PM UTC
Hi John,
Agree with Gio on defining a scripted parameter.
I'll give an example. A Scripted (Tcl) Parameter with this script provides the directory path of the source dataset.
return [file dirname $FME_MacroValues(SourceDataset_SHAPE)]
Just be aware that this example is valid only when SourceDataset_SHAPE represents a single file path.
Takashi
gio
  • Jun 16, 2014 1:58 PM UTC
another note i forgot to mention.
The definition of the $out parameter must be done prior to the referencing of this $out parameter.
This order you can set in the paramter section in the navigator panel, you can drag one above the other
  • Jun 16, 2014 2:06 PM UTC
alternatively, you can also change type of DestDataset_SHAPE parameter to "Scripted (Tcl)" and then define a script directly for the parameter ;)
gio
  • Jun 16, 2014 2:28 PM UTC
with Takashi's tcl script it looks like this:
(zoom in a bit...)
gio
  • Jun 16, 2014 2:41 PM UTC
..lol..
Takashi is of course right..more efficient to directly script the DestDataset.
  • Jun 17, 2014 3:59 AM UTC
Thanks Gio and Takashi... solution worked like charm.
arthy
Forum|alt.badge.img+8
  • Oct 28, 2016 4:41 PM UTC
Please could you provided the TCL script to define the folder output writer based on the file input reader name?
Thanks
arthy
  • Oct 29, 2016 2:21 AM UTC
@gio,
Please could share the script to perfom such task?
Thanks
