Writer in UPDATE MODE
  • Jul 6, 2013 11:44 AM UTC
  • 26 views
   I am using a writer to update some non-geometry columns and one geometry. But it is only updating non-geometry columns.
I have explicitly set following parameters.
Writer Mode: UPDATE
Target Geometry Column Name: GEOM
fme_where: id
Am i missing anything?
Subrat.
Best answer by david_r
fme_where probably isn't relavant here.
Have you specified "Update key fields" on the output feature type? It should be set to ID, if that is your primary key.
David
  • Jul 8, 2013 6:30 AM UTC
David
