I'm trying to overwrite a feature in a file geodatabase but i always get the same error
Geodatabase Error (-2147024894): The system cannot find the file specified.
Could not open File Geodatabase dataset `P:\\vmmGeoDB\\IND.gdb' for writing.
Am i missing something?
Whe i try to do the same thing with af shp it works fine.
The intention is to write a shp to a fgdb.
Can somebody help me?
Thx!
Best answer by gerardo
Nath.:
I think that you might have a couple of things going on here:
1-I have a feeliong that it might be the gdb version that might be giving you trouble. Try upgrading the gdb to the newest verision of ArcGIS and re run the model. I would suggest creating a back up of the GDB before doing this.
2-Topology- check iof the gdb has any topologies in the feature dataset. if this is the case you might need to adjust your settings and set the Transaction type parameters to: "Edit Session" and rerun the model.
