Write shapefile with @value how Attribute Name
danilo_fme
Forum|alt.badge.img+45
Hi Team,
I have a simple example attached and it contain just a Reader and i would like to generate another shapefile.
The problem is: the Writer ( using the transformer FeatureWriter ) needs contain one Attribute:
@Value(De_Produto)
I tested to get the value from the source attribute De_Produto configurating the Writer, but without success:
How can i get the value attribute and transform the value this attribute as Attribute Name my Writer?
Thanks in Advance,
Danilo
Best answer by pallegama
Hi danilo_inovacao
The solution for this is using 'SchemaSetter'.
This will return the output as you expected as depicted in the image.
You need to add a 'SchemaSetter' transformer just before the 'FeatureWriter' and set the 'Schema Sources:' to "Schema From Schema Feature" under 'Dynamic Properties' in the 'FeatureWriter'.
'SchemaSetter' add the new attribute you created using a value of another attribute to the schema of the feature.
Instructing 'FeatureWriter' (this can be done in any 'Writer' as well) to use Schema Feature as the source of schema allows it to pass the correct schema set by 'SchemaSetter' into the output.
Please see the attached workspace for more information.
workspace-value-attribute.fmwt
danilo_inovacao
erik_jan
Forum|alt.badge.img+18
  • July 18, 2017
Danilo,
From the screenshot it looks like you have the Writer in Dynamic mode.
If you switch to Manual you can add the attribute.
danilo_fme
  • July 18, 2017
Hi @erik_jan, thanks your reply.
I changed the mode Writer to Manual and used the transformer SubstringExtractor to clean up the value, because has space and special caracter.
When i execute without transformer FeatureWriter the result is OK ( image OK.png ). But the results is not good when i generate the shapefile output ( image agora.png ).
Thanks
erik_jan
  • July 18, 2017
Have a look at the AttributeDereferencer transformer.
I believe that is what you need.
danilo_fme
  • July 18, 2017
Hi @erik_jan,
The log error when i open the shapefile in FME Data Inspector:
The 'FFS' reader was destroyed successfully
Failed to display the table contents due to the following error:
Feature specification `saida_De @Value(De) %0:<missing_232f> De_Produto %1:<missing_232f> Qtde_Produ %2:<missing_232f> De %3:<missing_232f>' in mapping file row `FFS saida_De @Value(De) %0:<missing_232f> De_Produto %1:<missing_232f> Qtde_Produ %2:<missing_232f> De %3:<missing_232f>' is not valid -- it has an invalid number of entries
Program Terminating
Translation FAILED.
erik_jan
  • July 18, 2017
danilo_fme wrote:
Hi @erik_jan,
Program Terminating
Translation FAILED.
Hmm, I played around with it and do not get it to work either.
Hope somebody else has a solution.
pallegama
Forum|alt.badge.img+8
  • July 19, 2017
Hi danilo_inovacao
danilo_inovacao
  • July 19, 2017
Hi @danilo_inovacao, I don't think you can define an attribute name for a destination feature type using an attribute value contained by a feature to be written. FME seems to configure the schema of a destination feature type before the first feature is written, so I think that FME has no chance to refer any feature attribute value while configuring a destination schema.
danilo_fme
  • July 19, 2017
Hi @erik_jan, thanks :)
danilo_fme
  • July 19, 2017
pallegama wrote:
Hi danilo_inovacao
danilo_inovacao
Hi @pallegama, thanks your help and Workspace template. This Custom transformer is very powerful :)
So i have a question: If i would like to have just this attribute FERTILIZ in my shapefile writer, how can i get it?
Thanks one more time.
Danilo
danilo_fme
  • July 19, 2017
Hi @takashi, thanks your information. And i tried with the custom transformer SchemaSetter mencioned by @pallegama, and my writer was generated with all attribute values from my source data too.
And this action to define an attribute name for a destionation using an attribute value i believe that can be create in future versions :)
Thanks,
pallegama
  • July 27, 2017
Danilo
Sorry for the delay to respond your question. You might have figured out this yourself by now. However, as depicted in the attached workspace template, you can use an AttributeKeeper at the beginning to retain the required attributes only (deselection of attributes at Reader just hide them without actually discarding them from the process).
Then the SchemaSetter can be used to remove all other attributes you do not required.
Please make sure to remove any attributes in the writer as well.
Regards, Priyantha Pallegama
