Write LandXML for Civil3D
  • Oct 21, 2017 5:17 PM UTC
  • 143 views
jatoxa
Forum|alt.badge.img+12
I'm trying to write a landXML file for import in Civil3D. I have used the template from an old article that writes the metadata. I can get out a file that contains the geometry and the metadata but it won't load in Civil 3D.
I have no idea how to get it to work and I have never found anyone that got it to work either in real life or on the internet. Why is documentation so scarce? It seems most people even from Safe only provides half answers on any of the prior threads on this issue.
Thanks!
/Jacob
jatoxa
  • Oct 22, 2017 11:12 AM UTC
I solved it now, I'll post the solution in here later when I find a more elegant solution.
jatoxa
  • Oct 23, 2017 8:45 AM UTC
The solution is basically to use the template from the article that specifies all the meta-data. To write the geometry you add a writer with the feature name "Surface" and create attributes for "Name" and "State". Name can be whatever and you can have multiple surfaces. State value needs to be set to "existing" for Civil3D to show it.
  • Jul 27, 2018 1:30 PM UTC
Thank you very much for this usefull tip !!!
