Write 3D solids with tags to dgn
  • Jun 30, 2015 10:59 AM UTC
  • 79 views
olof
Hello,
I'm trying to write tags to a dgn-file on 3D solids which i have generated in FME but no tags appear. It works fine if I use other geometry types i.e. igds_shape but then I do get a lot of features which I would like to avoid.
This message makes me want to ask if anybody out there has found a workaround:
DESIGN WRITER: Tag writing is currently not supported for the associated element
Best regards
Olof
Forum|alt.badge.img+54
  • Jun 13, 2019 1:11 PM UTC
I'm encountering the same issue
  • Jun 18, 2019 1:50 PM UTC
The associated element is an IFMEExtrusion btw, which seems to be the only igds_3d_solid that is supported
