Workspace Runner runs only with Source of Child Workspace
I want to run a Workspace with each run a different Shapefiles as Source.
I Use the "Directory and File Pathnames" Reader and set it to *.shp.
Then i set the Source of the Shapefile in the Workspacerunner to windows_path.
And here is the Problem:
Now the Child Workspace runs with the Child Workspace Source Shapefile.
But so many times as the "Directory and File Pathnames" Reader from the Main Workspace has.
It doesnt get that he needs to Change the Source to another Shapefile in the Childworkspace.
It only runs 8 times with the Child Workspace Source instead of Using the 8 different Shapes from the "Directory and File Pathnames".
What am i doing wrong?
Best answer by oscard
Is the Child Workspace using the same source parameter for the SHAPE as the one you have used in the Workspace Runner?
oscard
Forum|alt.badge.img+21
  • December 16, 2019
  • December 16, 2019
In the Child Workspace is only one of the 8 Shapefiles defined. In the Workspace Runner there are all 8 Shapefiles.
oscard
  • December 16, 2019
Yes, but the Reader in the Child has a parameter linked to its source. That paremeter should appear in the WorkspaceRunner of the Father workspace.
Could you add a couple of screenshots? One with your Child user parameters and other with the WorkspaceRunner parameters.
  • December 16, 2019
I cant send Screenshots because of the Paths and Filenames. Im not allowed to.
Child is Like:
"R:\\bla\\1_bla.shp"
and WorkspaceRunner is Like:
ESRI SHAPE Source: windows_path
and my Directory and File Pathnames has:
windows_path:
R:\\bla\\1_bla.shp
R:\\bla\\2_bla.shp
R:\\bla\\3_bla.shp
oscard
  • December 16, 2019
Child is Like:
windows_path:
R:\\bla\\1_bla.shp
R:\\bla\\2_bla.shp
R:\\bla\\3_bla.shp
What are the name of the parameters? Check in the Child the name of the User Parameter for the SHAPE source. Make sure is the same name you have in the WorkspaceRunner of the father for the SHAPE source.
  • December 16, 2019
I don't quite understand. Can you give me an example and send me screenshots of what and where should be the same?
The Readers Parameter of the Child is:
Shape name: 1_bla
Reader: 1_bla [ESRISHAPE]
and in the WorkspaceRunner i set it to windows_path and the windows_path has the path to 1_bla and the other Shapes
oscard
  • December 16, 2019
Shape name: 1_bla
All the SHAPES have the same schema?
Maybe the problem is that you are not using a Dynamic workflow.
  • December 16, 2019
the shapes were all created by the same process. If I change 1_bla to 2_bla in the Child Workbench the Child Workbench still works.
Edit: Do i need a dynamic reader in the Child workbench? if so how can i do it?
oscard
  • December 16, 2019
OK. So I go back to my first thought. I think there could be a problem with the parameters.
When you add the SHAPE in your Child Workspace, a user parameter is generated:
That is the parameter in the WorkspaceRunner that should have the "windows_path" value.
  • December 16, 2019
I changed the Reader from the Child Workbench from "R:\\bla\\1_bla.shp" to "R:\\bla\\*.shp".
Then in the WorkspaceRunner Parameter a new Line showed up with "Feature Types to Read". I clicked on the 3 dots and selected 1_bla to 8_bla.
Now it works
Edit: First select the Feature Types to Read in the WorkspaceRunner and then Change the shape Source to windows_path in the Workspace Runner otherwise there will be an error
