Workspace hangs while reading from MS SQL Server
  • Oct 20, 2016 1:09 PM UTC
  • 6 replies
  • 84 views
In my workspace I am reading from a table in SQL Server. There is a huge amount of records, so I limit the number of records to read (per feature type) to 100k for testing purposes. When the number of features read gets to about 99000, the workspace does not proceed for about 15 minutes. Is there anything I can change here?
itay
Forum|alt.badge.img+19
  • Oct 20, 2016 2:00 PM UTC
Lower the number of features to read?
  • Oct 20, 2016 2:02 PM UTC
Are there any clues in the FME log?
  • Oct 20, 2016 2:20 PM UTC
When I lower the number of features to read, for example 10k, it stalls before it reaches that number.
  • Oct 20, 2016 2:22 PM UTC
The log only shows "Reading source feature # 100000"
steveatsafe
Forum|alt.badge.img+16
Are you just reading features and nothing else in the workspace? Or is there something else (another transformer) causing the delay? If so disable anything after the reader to isolate that it is indeed just the reader.
itay
  • Oct 21, 2016 8:28 AM UTC
A good place to give your debugging effort a start and structure is the following article:
https://knowledge.safe.com/articles/19301/root-cause-analysis-guide.html
