Workspace freezing
  • Aug 28, 2024 11:50 AM UTC
  • 149 views
mr_fme
Forum|alt.badge.img+9
Sometimes after running some workspaces, the process freezes at the point shown below:
The workspace doesn't run anymore. It can stay like this for hours and not progress... Has this happened to anyone else?
Best answer by thomasmarti
Furthermore I see 2 warnings in your log, these could be interesting as well for your problem.
these 2 warnings are the 2 lines, written in blue. that’s not the problem.
The next line atfer Strarting translation should be:
Current FME version: FME 2021.2.6.0 (20220727 - Build 21821 - WIN64)
so I think it is a problem with the FME license.
lambertus
Forum|alt.badge.img+25
  • Aug 30, 2024 7:17 AM UTC
@mr_fme thats sounds interesting. It looks like you are using FME via ESRI ? Maybe there is something wrong with licensing, you could try to reach the ESRI support.
thomasmarti
  • Aug 31, 2024 10:11 PM UTC
