Workbench crashes when update to later version
  • Apr 21, 2026 12:35 PM UTC
  • 119 views
emmylm
Participant
I’ve several fme-worbench created in vers. 2023.2. When I update FME to later versions such as, 2025.2.4 or 2026.1 this warning below pops-up and the run crashes mor or less.
“Running (.fme) Mapping Files is deprecated. Please see http://fme.ly/fmeMappingFileDeprecation for more information”
Any ideas why and what I can do?
  • Apr 21, 2026 2:09 PM UTC
What are the file extensions? *.fmw or *.fme?
gabriel_hirsch
Forum|alt.badge.img+15
Are you running old hand-written mapping files with the .fme extension?
DanAtSafe
Forum|alt.badge.img+23
  • Apr 21, 2026 8:25 PM UTC
Hi ​@emmylm  That should be just a warning if you’re running a mapping files (*.fme) from the command line, but the warning can also appear if a sub-process is run (which shouldn’t happen - FMEFLOW-26222)
Either way, it shouldn’t cause FME 2025.2.4 or 2026.1 to crash. Please submit a ticket.
