WMS URL with a Drive Letter in
  • Nov 17, 2020 12:26 PM UTC
  • 40 views
joe.fme
Hi all, I've been asked to read a WMS which starts with a regular looking URL, which then forwards to a URL which is proving difficult.
The URL looks as follows -
http://<url>.co.uk/WMS/MS/7.2.1/mapserv.exe?map=D:\\Websites\\<service>\\Services\\WMSSHARE\\map\\Layers.map&SERVICE=WMS&VERSION=1.1.1
The part that's giving me trouble is where the D:\\ is. I've tried enclosing the URL in speechmarks and using a pythonCaller to workaround this, but so far I've had no luck. I managed to get the URL changed once, but it just forwards to this one, which is causing issues.
Has anyone else experienced something like this?
  • Nov 17, 2020 2:18 PM UTC
Convention is to use so-called URL-encoding on all parameters, in particular ":" is not allowed used unencoded in a URL parameter. You can try using a TextEncoder in mode "URL (Percent encoding)" on the value side of each parameter, so that you get
...?map=D%3A%5CWebsites%5C%3Cservice%3E%5CServices%5CWMSSHARE%5Cmap%5CLayers.map&...
joe.fme
  • Nov 17, 2020 2:36 PM UTC
Hi David,
Thank you for your reply, but still no luck. I feel I may have to go back to the person who's hosting the URL and see if I can get that colon removed.
