Will my current FME Server 2018.1 play with SQL Server 2017
  • Aug 19, 2019 4:04 PM UTC
  • 89 views
agelfert
Forum|alt.badge.img+8
In the process of migrating a number of SDE databases to SQL Server 2017.... will my current FME Server 2018.1 play along? I've tried to find a simple technical specifications document online but wasn't successful. Thanks. (In other words: is FME2018.1 compatible with SQL 2017?)
Best answer by laurawatsafe
Hi @agelfert, yes, FME 2018.1 is compatible with SQL Server 2017.
laurawatsafe
Forum|alt.badge.img+14
  • Aug 23, 2019 9:31 PM UTC
agelfert
  • Jan 2, 2020 10:40 PM UTC
@lauraatsafe, thanks for the into back in the summer. Been pulled a million directions and just now testing with SQL 2017. Are there any upgrades needed - a little confused as to SQL Native Client? Getting some error messages. (cross posted from here) - Do I need to rely on Native Client 2012 still or install the OLE DB Driver for SQL Server? Thanks.
