Why won't my Web Service Call work?
  • Apr 27, 2018 4:36 PM UTC
  • 67 views
pauldeq
I am trying to connect to an external database using a web call service through the EPA (located here:
https://www.waterqualitydata.us/portal), but when I use the link from the web service at the bottom of the page under "Show Web Service Calls", i get this error. I think this has something to do with the fact that the service sends the data pulled in a Zip file, and FME can't get passed that to get to the data? Here is the "logfile" that I get after I try to pull it. The file is an Excel File, but again it is bundled into a Zip file:
Starting translation...
FME 2017.1.0.0 (20170731 - Build 17539 - WIN32)
FME Database Edition (floating)
Permanent License.
Machine host name is: D22761
Operating System: Microsoft Windows 7 64-bit Service Pack 1 (Build 7601)
Copyright (c) 1994 - 2017, Safe Software Inc.
Safe Software Inc.
Potentially retrieving dataset 'https://www.waterqualitydata.us/data/Station/search?providers=STORET&mimeType;=csv&zip;=yes&sorted;=no' for reader
Retrieved file C:\\Users\\287394\\AppData\\Local\\Temp\\FME_TempFileStore_1524846318493_4344\\search for reader
Creating reader for format: Microsoft Excel
Trying to find a DYNAMIC plugin for reader named `XLSXR'
Loaded module 'XLSXR' from file 'C:\\Program Files (x86)\\FME\\plugins/xlsx.dll'
FME API version of module 'XLSXR' matches current internal version (3.8 20170315)
Excel Reader: Output cell formulas: 'false'
Excel Reader: Output cell comments: 'false'
Excel Reader: Force full datetime values: 'false'
Excel Reader: Opening dataset 'C:/Users/287394/AppData/Local/Temp/FME_TempFileStore_1524846318493_4344/search'...
Excel Reader: Failed to open the dataset 'C:/Users/287394/AppData/Local/Temp/FME_TempFileStore_1524846318493_4344/search'. Error message was 'Unknown exception'
Excel Reader: Closing dataset 'C:/Users/287394/AppData/Local/Temp/FME_TempFileStore_1524846318493_4344/search'...
Failed to obtain any schemas from reader 'XLSXR' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 1 minute 35.6 seconds. (CPU: 0.5s user, 0.3s system)
END - ProcessID: 4344, peak process memory usage: 90432 kB, current process memory usage: 69292 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\287394\\AppData\\Local\\Temp\\FME_1524846317593_6308.
The web service call is this URL:
Please help. (Note: I have also tried this as a CSV pull, and I get the same issue, hence why I think it has something to do with the fact that the data get sent in a Zip file.)
danilo_fme
Forum|alt.badge.img+58
  • Apr 27, 2018 10:33 PM UTC
Hi @pauldeq
I did simulate your situation here in my note with the version FME 2018.
1) The transformer Creator was used to do a trigger in the Workspace.
2) The transformer HttpCaller was connected the URL and do the download zipfile to local by the configuration = Save Response Body to.
3) The zipfile was extracted by transformer FeatureReader.
Attached the Workspace - workspace-url.fmw
Thanks,
Danilo
pauldeq
  • Apr 30, 2018 11:53 AM UTC
Hi @pauldeq
Thanks,
Danilo
Thank you for the response. I really appreciate it. So, first, I noticed you did this in FME 2018. I have the 2017 version. I downloaded your workflow into the 2017 version, and I am having some issues. When I run it, I get a dialog box called "Generating Output Ports", generatingoutputports.jpg. The only option I can do in the Dialog is cancel, because I dont know where to get the "Dataset" its looking for. After I run the workflow, I don't see any data under the "generic" inspector. Just gives me one column of nothing.
