Why the File Copy writer doesn't log an error when the file doesn't exist?
  • Apr 23, 2020 2:59 PM UTC
  • 101 views
rbovard
Hi there!
Do you know why the File Copy writer doesn't log an error when the source file doesn't exist?
It only logs an warning:
File Copy Writer: Ignoring the destination filename '<file>' because the source dataset '<path\to\file>' was not a file.
It was problematic in my case because I monitore only the errors in the log files... :/
Thanks in advance for your feedback,
Rémi
Best answer by ebygomm
Do yu have this parameter set?
Forum|alt.badge.img+54
  • Apr 23, 2020 3:01 PM UTC
rbovard
  • Apr 23, 2020 3:16 PM UTC
Oh, you're a genius! Thanks a lot for this amazing quick answer!
