why I can not create a new table to Postgis
esaka
Participant
  • Participant
When I would like to insert a new table to Postgis, I am getting below error. For existing table is ok. Its means that, it is inserting a new records, but if does not exist table, it does not allow to create.
Best answer by takashi
Hi @esaka, most likely the error message "Schema 'gis' is not a valid schemaname" indicates that the schema 'gis' within which you are going to create a new table does not exist in the destination database. Firstly check if the schema exists, with pgAdmin. The pgAdmin is a convenient tool to manage PostgreSQL/PostGIS databases.
  • May 21, 2018
esaka
Participant
  • Participant
  • May 21, 2018
Thankyou Tahashi,
There was no schema as "gis". Actually, gis was my database name.
I was trying to insert to "public" shame. However, I created a new schema as "gis" and it did.
Thank you again.
