Why I can not access OData in my FME desktop 2013?
  • Feb 4, 2014 2:24 PM UTC
  • 54 views
aguan
Forum|alt.badge.img+11
I published an OData service from Composite Studio (from Composite Software). It is in ATOM format that FME Desktop 2013 supports.  I can see the http URL in browser but can not access it in FME reader. It does not give an error message. The log file shows:
Trying to find a PYTHON plugin for reader named `ODATA'
OData Reader: Directive 'SERVICE_URL' has the value 'http://dalwcompd01.nexenusa.ad:9400/odata/TGS_LOGS'
OData Reader: Directive 'USER_NAME' has the value '['admin', 'admin']'
OData Reader: Connecting to service 'http://dalwcompd01.nexenusa.ad:9400/odata/TGS_LOGS/'
OData Reader: Retrieving feed names from service 'http://dalwcompd01.nexenusa.ad:9400/odata/TGS_LOGS/'
OData Reader: Reading schema data ...
Merged 0 schema features read from 1 datasets into 0 resulting feature types
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >http://dalwcompd01.nexenusa.ad:9400/odata/TGS_LOGS<
Reader Parameter(1) = >USER_NAME<
Reader Parameter(2) = >admin<
Reader Parameter(3) = >PASSWORD<
Reader Parameter(4) = >********<
Reader Parameter(5) = >_MERGE_SCHEMAS<
Reader Parameter(6) = >YES<
Reader Parameter(7) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(8) = >YES<
Reader Directive(0) = >RUNTIME_MACROS<
Reader Directive(1) = >USER_NAME,admin,PASSWORD,********,_MERGE_SCHEMAS,YES,RETRIEVE_ALL_TABLE_NAMES,YES,_MERGE_SCHEMAS,YES<
Configuration object contents:
FME Temporary Directory: C:\\Users\\guana\\AppData\\Local\\Temp
mapping file Line 0: `APPLICATION' `FME_WORKBENCH'
mapping file Line 1: `AUTOREG' `YES'
mapping file Line 2: `LOG_MAX_FEATURES' `-1'
mapping file Line 3: `LOG_APPEND' `NO'
mapping file Line 4: `FME_HOME' `C:\\Program Files\\FME\\'
mapping file Line 5: `FME_SESSION_USED' `TRUE'
mapping file Line 6: `R_33_METAFILE' `ODATA'
mapping file Line 7: `R_33_DATASET' `http://dalwcompd01.nexenusa.ad:9400/odata/TGS_LOGS'
mapping file Line 8: `R_33_USER_NAME' `admin'
mapping file Line 9: `R_33__MERGE_SCHEMAS' `YES'
mapping file Line 10: `R_33_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 11: `R_33_USER_NAME' `admin'
mapping file Line 12: `R_33__MERGE_SCHEMAS' `YES'
mapping file Line 13: `R_33_MERGE_SCHEMAS' `YES'
mapping file Line 14: `R_33_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 15: `R_33__MERGE_SCHEMAS' `YES'
mapping file Line 16: `R_33_MERGE_SCHEMAS' `YES'
mapping file Line 17: `ODATA_USER_NAME' `'
mapping file Line 18: `SCHEMA_TIME' `YES'
mapping file Keyword: `R_31_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_3_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_33_METAFILE'                          occurs 1 time(s)
mapping file Keyword: `AUTOREG'                                occurs 1 time(s)
mapping file Keyword: `R_7_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_28_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_22_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_17_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_33_PASSWORD'                          occurs 2 time(s)
mapping file Keyword: `R_24_DEF'                               occurs 0 time(s)
mapping file Keyword: `FME_SESSION_USED'                       occurs 1 time(s)
mapping file Keyword: `R_25_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_23_DEF'                               occurs 0 time(s)
mapping file Keyword: `LOG_MAX_FEATURES'                       occurs 1 time(s)
mapping file Keyword: `R_32_DEF'                               occurs 0 time(s)
mapping file Keyword: `ODATA_PASSWORD'                         occurs 1 time(s)
mapping file Keyword: `R_2_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_18_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_29_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_30_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_12_DEF'                               occurs 0 time(s)
mapping file Keyword: `FME_HOME'                               occurs 1 time(s)
mapping file Keyword: `R_6_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_21_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_5_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_33_MERGE_SCHEMAS'                     occurs 2 time(s)
mapping file Keyword: `R_1_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_9_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_26_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_14_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_33_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_4_DEF'                                occurs 0 time(s)
mapping file Keyword: `R_16_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_11_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_15_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_33__MERGE_SCHEMAS'                    occurs 3 time(s)
mapping file Keyword: `APPLICATION'                            occurs 1 time(s)
mapping file Keyword: `R_19_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_20_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_13_DEF'                               occurs 0 time(s)
mapping file Keyword: `R_33_USER_NAME'                         occurs 2 time(s)
mapping file Keyword: `R_33_DATASET'                           occurs 1 time(s)
mapping file Keyword: `SCHEMA_TIME'                            occurs 1 time(s)
mapping file Keyword: `R_27_DEF'                               occurs 0 time(s)
mapping file Keyword: `LOG_APPEND'                             occurs 1 time(s)
mapping file Keyword: `R_10_DEF'                               occurs 0 time(s)
mapping file Keyword: `ODATA_USER_NAME'                        occurs 1 time(s)
mapping file Keyword: `R_33_RETRIEVE_ALL_TABLE_NAMES'          occurs 2 time(s)
mapping file Keyword: `R_8_DEF'                                occurs 0 time(s)
Anybody knows why?
Best answer by sigtill
I am guessing some settings on the Reader. Or that you read one Atom feed - and then changed the "Features". Have you tried deleting the Reader and adding a new one?
sigtill
Forum|alt.badge.img+25
  • Feb 5, 2014 4:51 PM UTC
