WFS with spaces not working
  • Dec 11, 2018 1:49 PM UTC
  • 129 views
I'm trying to fetch data from the following WFS with a WFS-reader:
http://geodata.nationaalgeoregister.nl/bag/wfs?service=wfs&request=GetFeature&typeName=bag:pand&cql_filter=bag:identificatie LIKE '%25158110%25'
When I browse it in IE it works fine, but FME throws me the next error:
<WFS> An Exception Report was produced performing a `GetCapabilities' request
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1" version="2.0.0" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://geodata.nationaalgeoregister.nl/schemas/ows/1.1.0/owsAll.xsd">
  <ows:Exception exceptionCode="NoApplicableCode">
  Â  <ows:ExceptionText>Could not parse CQL filter list.
Lexical error at line 1, column 18. Â Encountered: &amp;quot;%&amp;quot; (37), after : &amp;quot;&amp;quot; Parsing : bag:identificatie%20LIKE%20&amp;apos;%158110%&amp;apos;.</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
A fatal error has occurred. Check the logfile above for details
I think the spaces in de cql-filter are causing problems. What is the right syntax for the WFS with the "like"-command?
Greetings Erwin
  • Dec 11, 2018 1:54 PM UTC
You need to URL-encode the CQL clause to get rid of invalid characters, such as spaces, etc. You can use the TextEncoder for this, the result should look something like this:
cql_filter=bag:identificatie%20LIKE%20%27%25158110%25%27
Make sure that you only URL-encode what comes after the equal sign.
  • Dec 11, 2018 2:33 PM UTC
Thanx David, but the result is still the same. I changed the WFS-URL into
http://geodata.nationaalgeoregister.nl/bag/wfs?service=wfs&request=GetFeature&typeName=bag:pand&cql_filter=bag:identificatie%20like%20%27%25158110%25%27
But the same error occurs:
url: 'http://geodata.nationaalgeoregister.nl:80/bag/wfs?SERVICE=WFS&REQUEST=GetCapabilities&cql_filter=bag:identificatie%20like%20'%158110%'&VERSION=2.0.0'
Lexical error at line 1, column 18.  Encountered: &amp;quot;%&amp;quot; (37), after : &amp;quot;&amp;quot; Parsing : bag:identificatie%20like%20&amp;apos;%158110%&amp;apos;.</ows:ExceptionText>
  </ows:Exception>
trentatsafe
Forum|alt.badge.img+7
Hello @reijnen,
I believe the issue with the URL is the ECQL clause. I don't believe FME currently supports ECQL but rather uses the OGC XML Filter. An example of an XML Filter can be found here: https://knowledge.safe.com/questions/5017/how-to-use-the-xml-filter-in-the-wfs-reader.html
If this is functionality you would like to see added to FME, please submit an idea here: https://knowledge.safe.com/content/idea/list.html
I hope that helps!
itay
Forum|alt.badge.img+19
  • Dec 11, 2018 9:32 PM UTC
Hi, @reijnen
I have used a cql_filter on a WFS service in the past but not via the reader, but by using the HTTPCaller.
See the HTTPCaller_wplWPL transformer in the FME Hub template here
