WFS FeatureReader not outputting any of the selected layers
  • Jun 18, 2019 2:17 PM UTC
  • 5 replies
  • 111 views
I am trying to use a WFS FeatureReader. I'm not getting any errors and it is outputting the schema and initiator but not the actual layer that I have selected
It's almost as if it isn't in the correct coordinate system however I have cheked multiple times and with multiple WFS links and it's just not working.
I am trying to select the "WFS Output Format" but there are no options in the drop down menu. I'm wondering if this is the issue? Or is anyone else having the issue of WFS FeatureReaders not wokring. I'm using FME 2019
palhermans
Forum|alt.badge.img+11
  • Jun 18, 2019 10:07 PM UTC
WFS's can be a pain, to assist I think you have to provide the URL to the GetCapabilities call (or save the response and provide it here). Specifying the output format has been a key in some cases - yes.
  • Jun 20, 2019 7:30 PM UTC
The WFS is https://data.linz.govt.nz/services;key=4b8923f859d94ceb8058ea65863e2588/wfs/layer-51571?service=WFS&request=GetCapabilities
I'm having issues with all of the LINZ WFS actually with different inputs.
palhermans
  • Jun 21, 2019 9:12 AM UTC
Hi @ctsmithgis thanks for the GetCapabilities. My knowledgde in WFS is a bit limited and I might be mixing WFS 1.x and 2.x nomenclature in my response, and some might even be mistakes and/or errors.
GetCapabilities
The service supports both GET and POST (AGOL just support POST). The outputFormat "section" describes a lot of possible output formats, many of them non-standard according to WFS specs (for example KML). If my understanding is correct output formats depend om the WFS version of your request (for the standard outputs). The safe thing is to ask for the standard outputformat probably (?).
Test
- version: I used 2.0.0
- output format: text/xml; subtype=gml/3.2 (I believe this is standard for 2.0.0)
If You choose to go for WFS versions 1.0.0 or 1.1.0 you might have to change outputformat accordingly. This got me going (with FME2018) .
palhermans
  • Jun 21, 2019 11:33 AM UTC
GetCapabilities
Test
An image attached. Please note I limited the request to 10 objects only
palhermans
  • Jun 21, 2019 11:50 AM UTC
GetCapabilities
Test
One other thing. It seems the webserver/IIS is not allowing POST. That could be the reason for "Prefer HTTP Post if available" fails if You try
