We installed FME 2019 and i recieve a java error.
  • Apr 26, 2019 6:05 PM UTC
  • 110 views
Hello we installed the new FME 2019 and when i try to use the LDAP reader i recieve the following error:
Is there something required to ahve java work in the new version of FME?
The workspace may run slower because features are being recorded on all output ports.
The Java Virtual Machine could not be started. CLASSPATH = '-Djava.class.path=C:\\Program Files\\FME\\common-webservices.jar;C:\\Program Files\\FME\\plugins;C:\\Program Files\\FME\\plugins\\commons-compress-1.17.jar;C:\\Program Files\\FME\\plugins\\dropbox-core-sdk-3.0.11.jar;C:\\Program Files\\FME\\plugins\\hsqldb.jar;C:\\Program Files\\FME\\plugins\\ili2c.jar;C:\\Program Files\\FME\\plugins\\ili2fme.jar;C:\\Program Files\\FME\\plugins\\jackcess-2.1.11.jar;C:\\Program Files\\FME\\plugins\\jackson-annotations-2.9.8.jar;C:\\Program Files\\FME\\plugins\\jackson-core-2.9.8.jar;C:\\Program Files\\FME\\plugins\\jackson-databind-2.9.8.jar;C:\\Program Files\\FME\\plugins\\jackson-dataformat-cbor-2.9.8.jar;C:\\Program Files\\FME\\plugins\\server-plugin-common.jar;C:\\Program Files\\FME\\plugins\\snsfactory.jar;C:\\Program Files\\FME\\plugins\\spanner-jdbc-1.0.9.jar;C:\\Program Files\\FME\\plugins\\sqsfactory.jar;C:\\Program Files\\FME\\plugins\\teradata_jdbc.jar;C:\\Program Files\\FME\\plugins\\tfs.jar;C:\\Program Files\\FME\\plugins\\ucanaccess-4.0.4.jar;C:\\Program Files\\FME\\plugins\\websocketfactory.jar;\\\\domain2\\infrastructure\\Users\\thompsonp\\Documents\\FME\\Plugins\\Java'. Return code is '-1'
JVM Message: Error occurred during initialization of VM
JVM Message: java/lang/NoClassDefFoundError
JVM Message: : java/lang/Object
steveatsafe
Forum|alt.badge.img+16
@cob.pthompson
Did you get past this one? I did a quick test and was having issues connecting but not this Java error you have shared. When do you see this error? After making the connection and then attempting to run the workspace? OR do you see this when trying to make a connection in the first place to the LDAP server?
