Using Parameters in END SQL
  • Apr 10, 2013 3:10 PM UTC
  • 6 replies
  • 74 views
Hi
I'm having an issue using a User Paramater inside the END SQL with the Oracle Writer.
I can use it in the WHERE clause on the Reader no problem but using the same format on the END SQL is causing me some problem. I'm sure it is something simple that I've missed!
Reader WHERE:
USERUPDATED = '$(P_USERNAME)'
Writer END SQL:
DELETE FROM DB_UPDATED WHERE USERUPDATED = '$(P_USERNAME)'
It literally tries to find the string $(P_USERNAME)
Here is the contrived example (yes I would normally do this in SQL!):
http://db.tt/kWQgcu3j
  • Apr 10, 2013 3:20 PM UTC
Hi Mark,
I've experienced some of the same issues, although not necessarily at the same place as you do). It seems that FME is not always entirely consequent in the way it expands parameter macros.
The only solution I know of is to create a Python scripted parameter that returns the entire contents and then to bind it to to the desired setting using right-click / link to parameter.
Example python scripted parameter
username = FME_MacroValues["P_USERNAME"]
end_sql = "DELETE FROM DB_UPDATED WHERE USERUPDATED = '" + username + "'"
return end_sql
David
  • Apr 10, 2013 3:30 PM UTC
Hi David
Fast repsonse as always - Do you live on here ? :-)
Your suggestion was what was similar to something I thought of but thought there must be something simple I'd missed!
My workaround was a Private Parameter (not Python Scripted) configured:
DELETE FROM DB_UPDATED WHERE USERUPDATED ='$(P_USERNAME)'
and link this to the END SQL
Mark
  • Apr 10, 2013 3:48 PM UTC
Hi Mark,
your solution is equally elegant, but you've probably discovered by now that I am a big fan of Python in FME, so there you go ;-)
David
PS: it's a question of being efficient while FME does its thing :-)
  • Apr 10, 2013 4:20 PM UTC
Have just realised it isn't a single query to execute :-(
Might use a SQLExecutor and a trigger of Creator with Create at End = Yes
mark2atsafe
Forum|alt.badge.img+59
Hi Mark,
You're correct that this doesn't work now. I'm not sure why but from my talks with the developers it seems that this could be implemented. So this is filed as PR#43215 and I will let you know when the fix is in place.
Regards
Mark
Product Evangelist
Safe Software Inc
  • Apr 18, 2013 8:35 AM UTC
Hi Mark,
I mailed the Safe Support Team and got an answer confirming this. Thanks for the reply on here.
Mark
