Using .dll files
  • Feb 22, 2020 10:56 AM UTC
  • 125 views
Forum|alt.badge.img+3
Hi FME Fans,
Is there a way to run a .dll file from within FME and also pass data to it?
Cheers
Forum|alt.badge.img+63
You could try the SystemCaller and execute the regsvr32 command. Not sure about passing data into the .dll, I would imagine that's done through parameters and as the SystemCaller allows you to construct a command line that would be the first thing to try.
  • Feb 24, 2020 8:11 AM UTC
The easiest may be to use the PythonCaller and the ctypes module, but it depends on the contents and the usage of the dll.
https://docs.python.org/3/library/ctypes.html
