Using dgn teigha file with FME safe software (OdDgCellHeader2d) fail to read igds_cell_name
  • Feb 23, 2023 7:48 AM UTC
  • 97 views
When we try to convert dgn file issued from teigha in FME software, we have troubles with OdDgCellHeader2d cell name.
imageit seems to be an encoding trouble. Teigha used UTF8 encoding and FME try to read an ansi string. Note that there is no trouble with the string linkage of the cell.
We have post on the teigha forum and aidan.wessel have answer.
We join a dgn file with two ERPTRL Cell, one dropped with teigha library and the other with microstation.
inside microstation, we have no trouble. FME is not able de read igds_cell_name for the one dropped by teigha library.
thanks for your answer,
best regards,
G. COSTAMAGNA
daveatsafe
Forum|alt.badge.img+24
  • Feb 23, 2023 10:47 PM UTC
Hi @gcostamagna​,
I have created a problem report for the FME development team (FMEENGINE-76702) and will notify you when this is resolved.
daveatsafe
  • Mar 13, 2023 5:42 PM UTC
Hi @gcostamagna​,
Hi @gcostamagna​,
We have fixed this problem in the latest FME 2023 beta, which can be downloaded from safe.com/beta
