Using an updated version of my Excel File in a workspace doesn't produce results
  • Mar 3, 2017 9:52 PM UTC
  • 39 views
fmelizard
Forum|alt.badge.img+22
I have a workspace with an Excel Reader and I want to change it to read a new version of the file. I can run the workspace with the new file and features are read in, but the resulting output contains blank values. How can I fix this?
brianatsafe
Forum|alt.badge.img+13
There is a setting under Advanced when setting up the Reader Parameters called "Scan Schema in Dynamic Workflow". Checking this should allow you to use different copies of the file with the same workspace. Check out the Excel reader documentation for more on that.
