Using a Box Web connection on my Directory and File Pathname reader error
  • Dec 12, 2018 1:11 AM UTC
  • 51 views
salvaleonrp
Forum|alt.badge.img+23
Using the said reader I configure my parameters as shown,
FME returns with the folder list from Box below
When I run my workspace I get this error
If I use the BoxConnector transformer it can only read one folder URL at a time but using the same web connection works.
All I want to do right now is build a folder list that reads the sub folder recursively. Later I'd like to use the exifreader to get metadata of the pictures stored in Box.
salvaleonrp
  • Dec 12, 2018 3:55 AM UTC
I'm attaching screenshot of another workspace using the BoxConnector transformer using the same Box folder.
The same log message from the Directory and Filename Path reader is only a Warning on the transformer. In the reader the message is an error.
What's interesting to note is the number used in the API call generated by FME. This number is not a folder ID or a file ID.
