UserParameter values as attribute name
  • Nov 28, 2024 8:32 AM UTC
  • 101 views
lambertus
Forum|alt.badge.img+25
I would like to use 2 UserParameter values as attribute names in my workbench. Is this possibe?
Current situation:
What I would like to have:
veschwab
Forum|alt.badge.img+26
  • Nov 28, 2024 2:53 PM UTC
This is surely not an elegant solution but it seems to do the job:
You can try an BulkAttributeRenamer since I found you can use User Parameters when choosing what suffix/prefix you want to add to the AttributeRename. You can just choose to Rename Selected Attributes and select the attribute for FirstMoment/SecondMoment and then choose the corresponding user parameter in the “string” parameter. Maybe these screenshots help:
