user parameter optional
  • Oct 8, 2015 10:40 AM UTC
  • 79 views
Hello,
I have a bunch of shapefiles as inputs but i'm not using them all everytime, so i put them as Optional in the User Parameter.
But i get this message : "Shape Reader: Failed to open dataset 'T:\\Test\\\\SHP\\test.shp' which is neither an existing file nor directory" when i run my script using a python script.
Eventhough the shapefile doesn't exist, since it's set as optional, FME should ignore it, no ?
How can I make it work please ?
pratap
Forum|alt.badge.img+12
  • Oct 8, 2015 10:59 AM UTC
Try setting "Ignore failed readers" to "Yes" in the Navigator under Workspace parameters -> Advanced.
  • Oct 8, 2015 11:54 AM UTC
Awesome ! I didn't about this parameter !
Thanks a lot !
