Use UserParameter for Writing OutputFile
  • Mar 10, 2016 9:04 AM UTC
  • 10 replies
  • 357 views
I want to use a UserParameter to define the OutPutFile, here a FileGeoDatebase.
The Path and Filename generated generically in the Workbench.
To make the Attribut to a Parameter is using a AttributCreator.
The ParameterType ist testing with Text, Folder (Output), Filename (Output).
No success
Forum|alt.badge.img+63
By default FME will create a DestDataset user parameter, check if it's in your Navigator (under User Parameters -> Published Parameters). If not, find it in the writer-part of the Navigator, right-click on it and choose "Create user parameter".
This way whenever the user runs the workspace with the prompt and run option there will be a message box popping up, allowing this parameter (and any others you may have defined) to be set.
  • Mar 10, 2016 10:26 AM UTC
Thanks for our answer
The Point is, that the workbench generated the Path, the Parameter can't published.
The User can't set the Parameter.
pratap
Forum|alt.badge.img+12
  • Mar 10, 2016 12:38 PM UTC
For how many FileGeoDatabases, do you want to define the path+filename?
Pratap
pratap
  • Mar 10, 2016 12:42 PM UTC
Have you tried Fanout in Advanced in Navigator tab?
Pratap
mark2atsafe
Forum|alt.badge.img+59
Yes, I think you should use a fanout. In there you can set the path and filename to an attribute value, even if you are only writing a single dataset.
If I understand correctly, that won't work. Parameters are set at the very start of a workspace and cannot be changed. You can't change the value of a parameter within a workspace.
  • Mar 10, 2016 4:11 PM UTC
1. One GeoDataBase
2. no FanOut
3. I hope I can Create a Parameter in a workbench.
tomorrow I testing a other way, not a AttributeCreator
patrick_koning
Forum|alt.badge.img+7
To overcome that problem u can use this
https://knowledge.safe.com/questions/4120/user-parameters-from-file.html
it reads out a config file that fills the user parameter before running the workspace.
mark2atsafe
I think we're all finding it hard to help based on your description. Perhaps you can upload a copy of your workspace so that we can see what is happening?
  • Mar 18, 2016 12:39 PM UTC
Hello Mark
what you says is correct, "You can't change the value of a parameter within a Workspace"
Sorry
That's why I have create a control Workspace, within two Jobsubmitter (for FME Server), the First create the Parameters, the second make the calculation.
Now I have Problems transfer the Parameters to the second workbench....
fmelizard
Forum|alt.badge.img+22
  • Mar 19, 2016 6:23 AM UTC
Maybe use a FeatureWriter instead of a traditional writer. Then it is easy to compute a value for the dataset? You can also use Dataset Fanout and then compute an attribute in a workspace and that can be used to control the output dataset as well.
