use the variable of an attribute for the name of a txt format writer
  • Nov 8, 2019 12:34 AM UTC
  • 109 views
fer_ruiz
I would like to know how to put as a name of the writer of type txt, to put "frg_ (variable) .txt where what is in parentheses is the attribute that I want to put so as not to have to change it myself.
danilo_fme
Forum|alt.badge.img+58
  • Nov 8, 2019 1:01 AM UTC
HI @ftl
In FeatureType ( Writer ) you can set this configuration:
Thanks,
Danilo
fer_ruiz
  • Nov 8, 2019 6:35 AM UTC
hi @danilo_fme
i need use the wrtiter "txt file", i seen a file with a example.
none2textline.fmw
in the red circle only apear "open text editor" and i can not choice attribute values.
regards:
Fer
Forum|alt.badge.img+54
  • Nov 8, 2019 8:38 AM UTC
If you want to automatically name your text file with an attribute name you need to fanout on the writer in the navigator
fer_ruiz
  • Nov 8, 2019 11:02 AM UTC
Many thank, this is that i need.
Regards:
Fer
