use listElementCounter to populate destination attributeValue
  • Nov 21, 2024 7:05 PM UTC
  • 64 views
gisbradokla
Forum|alt.badge.img+27
I have a list of Attributees{}.name That contains attributes for each feature. the element count is variable.
I am also using the ListElementExtractor and like how it works but i need from  15-258 attributes to put the list into.is there a way to get the list values out as attributes? or at the very least mmake the list populate (i.e. attr1, attr2, - attr258) in the destination attributes?
I am reading the schema from a (blank) gdb with coded domains and WAY too many attributes to use AttributeManager. the purpose is to get the attributes with the correct domain and values so a different schema can be fed into this format and output as gdb with domains intact.
geomancer
Forum|alt.badge.img+71
  • Nov 22, 2024 9:14 AM UTC
Take a look at the ListBreaker from FME Hub.
Note that you need to expose the attributes afterwards.
