Update data to a writer
  • Jun 11, 2026 3:33 PM UTC
  • 5 replies
  • 105 views
guimor33
Hello everyone,
I have an FME script that processes various data. Upon output, everything goes to a feature service. So far, so good; I have no problems during processing.
My issue is very simple to solve, I think, but I can't find the solution.
I'm working with agricultural data. For example, when using my script, I might request to use data labeled "18/19/11". Everything works fine, and everything displays perfectly.
The problem arises when I only want to work with data labeled "18". The script works perfectly again, and the data is correct up to the last transformer before the writer. However, the data in the writer isn't replaced by the new dataset, and I still get the "18/19/11" data when I only want "11"!
What type should I choose in "Feature operation" (insert/update/upsert/etc.) and in "feature type handling"?
Do I need to integrate a transformerbefore the writer that will update the datar, or is this problem solved solely within the writer? I'm a bit lost and frustrated...
Thank you very much in advance for your answers.
Have a good day.
guimor33
  • Jun 12, 2026 12:39 PM UTC
To export the data I use a writer ARCGISFEATURESERVICE.
Should I use instead the AGOL.ARCGISFEATURESERVICE or there no difference between them ?
I create a writer with a SHP format and the data are correct so I don’t understand why it’s not the same in my ARCGISFEATURESERVICE !
Thanks a lot !
crutledge
Forum|alt.badge.img+55
  • Jun 14, 2026 5:19 PM UTC
Hi ​@guimor33
If I understand correctly, you are looking to update the data in your feature service. Try Insert and then “Truncate Existing” in the table handling/feature handling. This will clear the table of records and write the new records. If you wish to keep and update existing then we have to handle in a different way.
Let us know if this works! Good luck and hope that helps!
guimor33
  • Jun 15, 2026 1:04 PM UTC
Hello !
I work on different point which represent different electrical substation. My “script” show the constraint within a 10km radius around the point. And at the same time my “script” show some agricultural field which are based on some type of culture. Sometimes I ask the “script” to indicate me the type of field like the category 18/19/16/25 and somethimes I juste want the category 18.
I use a WHERE CLAUSE in the “script”  where I noted the name of the electrical substation I want to work on. So when I want to use the “UPDATE”, it’s only on this area auround the elecctrical substation I noted.
So everytime I don’t want all my data to be updated but just the electrical substation I ask the script to run on.
When I UPDATE I got this error actually :
ArcGIS Feature Service Writer: Feature Service 'https://gis.qenergy.eu/arcgis/rest/services/FR_Prospection/Prospection_solaire_nationale_FME_poste_…' does not support writer mode 'UPSERT'. Its owner may have disabled inserting or editing features. Writes may fail if the current user is not the owner or administrator
Python Exception <WriterModeNotSupported>: FMEException: 928232: ArcGIS Feature Service Writer: Feature Service 'https://gis.qenergy.eu/arcgis/rest/servvices/FR_Prospection/Prospection_solaire_nationale_FME_poste_source/FeatureServer' does not support writer mode 'UPSERT'. Its owner may have disabled inserting or editing features. Writes may fail if the current user is not the owner or administrator
Is it a error that mean I got a problem with the parameter in ArcGIS feature service ? My administrator must change something to allow me to UPDATE ?. Or it’s a parameter in FME to change ?
I hope my explanation are clear (I’m not sure). But I can give you more details if needed !
Thanks a lot and have a goord day !
geomancer
Forum|alt.badge.img+71
  • Jun 15, 2026 3:32 PM UTC
The error message mentions that the Feature Service  does not support writer mode 'UPSERT'. So that is probably what goes wrong.
Aside from that, UPSERT will not delete existing records. UPSERT will only determine whether to UPDATE existing records, or INSERT new records.
So if the "18/19/11" data is already there, it will remain there. UPSERTing with "11” will only update or insert "11” records, it will not remove "18” and "19" records.
As ​@crutledge suggests above,
davechoi
Forum|alt.badge.img+15
  • Jun 17, 2026 3:29 PM UTC
​@guimor33 ArcGIS Server logs generated while the workspace runs might provide a clearer indication than the FME-side message on its own. You will likely need someone with ArcGIS Server credentials to reach them at https://<your-server-domain>/server/manager/log.html. On the Server Manager log page, set the Log Filter from Warning to Verbose, then press the Query button (visual example). Re-run the workspace and read the verbose entries for that run; the logs will tell you whether the service rejected the request on capability, permissions, or data issue.
If the ArcGIS Server message is also too ambiguous to troubleshoot, then I think submitting a support ticket to investigate further might be warranted.
Hope this help!
