Undefined macro `USER_ID' dereferenced in file error
  • Nov 12, 2013 9:40 AM UTC
  • 124 views
  I have 2 custom transformers embded in my main workbench. All are using same set of parameters. Hence, instead of each time
  changing all parameters, i tried to link parameters of 1st custom transformer to publish parameters of main workbench in Navigator.
  Workbench is executed successfully. but when i link any parameter of 2nd custom transformer, workbench is failing with following error.
"Undefined macro `USER_ID' dereferenced in file `C:\\Users\\mypc\\AppData\\Local\\Temp\\FME_138424666970_7432'
Undefined macro `%0' dereferenced in file `%1'
... Last line repeated 2 times ...
Oracle Writer: Translation aborted -- rerun specifying "ORACLE8I_1_START_TRANSACTION 0""
2nd custom transformer has one SQLExecutor, 1 test filter and 1 attribute creator.
Please let me know how to solve this issue.
Thanks.
  • Nov 12, 2013 9:55 AM UTC
I would recommend that you create a published parameter "USER_ID" in both your custom transformers. Then link the main parameter into it.
Something like this:
David
  • Nov 12, 2013 11:50 AM UTC
Hi David,
   Thanks. I also tried this approach. but not working.
  • Nov 12, 2013 12:28 PM UTC
it works for me. Just make sure that you do not reference the MAIN_USER_ID inside the custom transformer. Only reference the published parameter that is local to the custom transformer.
Also be aware that published parameters behave a bit differently inside a custom transformer if you access them using e.g. a PythonCaller. The safest bet is to use a ParameterFetcher inside the custom transformer and rather reference the resulting attribute.
David
