Unable to UPDATE any attribute field SDE connection, basically its an ArcFM Database. Please provide the valuable suggestion to update the same using FME 2021.2 32 bit. Help to solve, else need to look some arcobjects tool. #ArcFM #32bit #Utilit
  • Aug 8, 2023 12:37 PM UTC
  • 40 views
babint
Participant
WhatsApp Image 2023-08-08 at 5.57.29 PM
alexlynch3450
Forum|alt.badge.img+16
Not enough information supplied. There's 22 errors, but only see 15ish. Is this first time trying to update SDE using FME? Which Writer are you using? Does Writer work before encountering 'ELEC.CapacitorBank' feature class?
It could be as simple as your SDE user account does not have update privileges.
