Unable to expose attribute in FFS file
  • Jan 9, 2018 3:20 PM UTC
  • 50 views
I have an FFS file (created from a v7 DGN). This file has an attribute named "multi_writer_id" that contains the FFS file name. I can see this attribute in the data inspector but am unable to expose it with the AttributeExposer. I want to fan out the writer according to this attribute but because it cannot find the attribute, the result is a file named "NULL".
Any insight into what's happening?
jdh
Forum|alt.badge.img+41
  • Jan 9, 2018 8:22 PM UTC
I've never worked with multi-writer_id, just multi-reader, but there should be an fme_dataset attribute that contains the full file name, You can use a FileNamePartExtractor if you need just the root filename.
