Trying to run a workbench in FME Server via Job Submitter and find the output.
  • October 15, 2024
  • 5 replies
  • 56 views
seanlegeer
Hello, we are trying to use our FME server to run all of our data conversion via the API. We have created a workbench and uploaded it. We set the service to Job Submitter. When we run it we can not see were the output was written to.  The log indicates that job was run successfully but the log does not have any mention of an output location. We have tried to set the output File Geodatabase location to a network drive: “\\nos.noaa\MCD\FADS\FADS_Projects\FME_Workspace_Output\Weekly_Atons” and a local server drive: "F:\FME Server System share\repositories\Testing_Nate\ALL_USCG_Weely_Xmls_to_GDB\output\Weekly_Atons"
Any help would be greatly appreciated
todd_davis
Forum|alt.badge.img+22
  • October 15, 2024
Can you provide the job log of the process, as this should detail the locations you mentioned in it. So it would be good to see that, so that we can decipher what it is doing.
seanlegeer
  • October 15, 2024
That you for the quick response. The job log is attached.
todd_davis
  • October 15, 2024
Thanks.
So if you look at line 20 are all the parameters that are being passed to the process. I don’t see any output locations in here. So I assume you have instead hardcoded those locations into your writer, rather allowing a destination to be passed into the process?
So the file gdb should be getting written to the hardcoded value that you have in your writer. So you are hardcoding that value into the process?
seanlegeer
  • October 16, 2024
Here is a screenshot of the the writer’s output in this workbench. Does hardcoded mean that I give it a path instead of just a name?
todd_davis
  • October 16, 2024
Thanks for the screenshot, as that explains the problem.
It shows that you have linked it to the parameter “FME_DATA_REPOSITORY”. In FME Flow that parameter is held as a fixed value in FME Flow. So no matter what you pass that parameter it will not change. https://docs.safe.com/fme/2018.0/html/FME_Desktop_Documentation/FME_Workbench/!Transformer_Parameters/FME_Server_Parameters.htm
From your workspace log starting on line 20, you can see that:
FME_DATA_REPOSITORY' `F:/FME Server System Share/resources/system/temp/upload/
So that where you have been writing to.
So it would be best to create a new parameter (Let’s say ‘A’ for an example) and link that new parameter to that File Geodatabase location.
Then you can pass in the appropriate value as ‘A’ When you are calling the job to run.
