Transpose excel data by feature ID
  • Apr 12, 2024 9:06 AM UTC
  • 180 views
topotoma
Forum|alt.badge.img+4
Hello Community,
I have a question and looked for answers but didn’t find it yet.
It must be simple for someone but I have not yet figured it out. I tried attribute transposer, aggregator etc
I have a table with a feature which has an ID here shown as Feature 1,2,3 and multiple columns with values for each month of the year.
It is like so:
What I yould like to get is the following:
In the end I need a row for each column corresponding to the feature it is refering to.
I found some sort of a possibility but it it very “manual” an inelegant in FME as I have to create each month manually and associate a date etc.
If someone has a better idea, I am very interested about it. It would help me in the long run as I may have a wrong approach to transposing data with FME.
Many thanks to all the contributors.
Best regards, Thomas
Best answer by liamfez
I tried replicating your example data set and had some luck with the following method.
I used an AttributeExploder set to list, and keeping attributes. Followed by a ListExploder to explode that new list. Then I used an AttributeKeeper to keep only the ID attribute (POD in your case) and the attr_name and attr_value attributes. I followed this up with a Tester to remove features that were created for attr_name values that started with fme along with the ID.
Input was 3 features with an ID + 3 attributes. Output was 9 features with an ID and 2 attributes.
liamfez
Forum|alt.badge.img+44
  • Apr 12, 2024 12:59 PM UTC
topotoma
  • Apr 12, 2024 2:35 PM UTC
Dear liamfez,
It worked like a charm, thank you very much.
I had tried the attribute exploder but not with the settings you have indicated, but like this it is perfect.
Many thanks for your help ! it is greatly appreciated.
Have a good weekend.
Best regards,
Thomas
