Transferring attribute values
  • May 24, 2018 8:35 AM UTC
  • 5 replies
  • 74 views
Hello,
I am transforming DGN files to ESRI shape using (Attached bellow). I have a problem with shared cells elements. I am transforming them to point shp but I am losing attribute NAME. I am suspecting that some of the format attributes are not checked. Any ideas how to get attribute that i need?
Best answer by redgeographics
Without seeing your original DGN data it's a bit of a guess but I think if you expose the attribute igds_cell_name you'll find that that is the one you're looking for and then you can map it to an output attribute on your Shape writer.
Forum|alt.badge.img+63
  • May 24, 2018 9:11 AM UTC
I exposed igs_cell_name but nothing happend. I can't upload DGN file because it is about 3MB in size. I can upload it on Google Drive but i don't know if I am allowed to attach download link here.
Posting a download link is fine.
You'll need to do a bit more than just exposing the attribute. You'll also need to add it as an attribute on your Shape output and map it.
  • May 24, 2018 9:24 AM UTC
Sorry, i was looking at a wrong dataset. It's all good now. Thank you very much @redgeographics
You're welcome!
