.TML (Transducer Markup Language) to Shapefile (or any other usable format)
Can any one provide guidance on how to convert a .TML file to a ESRI shapefile for feature class?
Unfortunately I'm not able to upload the .tml and schema to this forum. They can be accessed here: https://drive.google.com/drive/folders/1pnvv5YCRYUE9h5OOt1dNf3jAChWL686F?usp=sharing
  • January 31, 2022
Some additional information on .TML: https://www.ogc.org/standards/tml#schemas
mark2atsafe
Forum|alt.badge.img+48
  • February 4, 2022
Normally I'd open this using the reader XSD-Driven XML. But I'm having a problem with your data. The TML file itself seems to be in a binary format, not plain XML. Do you know why? I tried "extracting" it in case it was a zip file, but that doesn't seem to work.
  • February 4, 2022
I don't know why it's binary format - that is how I received the data. I'll investigate..
