Timeout error 404 writer/arcgisonline
  • Dec 16, 2019 3:22 PM UTC
  • 7 replies
  • 66 views
Hello,
We use FME SERVER to transfer feature on arcgis online.
We always have a problem of timeout.
"ArcGIS Online Feature Service Writer: Encountered an unexpected error. The error code from the server was '504' and the message was: 'Your request has timed out.'. Details: ''
We try to send less packets each time bur the problem is the same.
Could you help us?
Best regards.
  • Dec 16, 2019 3:25 PM UTC
Which version of FME Server is this?
  • Dec 16, 2019 3:30 PM UTC
FME Server 2019.1.2
Thanks
  • Dec 16, 2019 3:33 PM UTC
Any proxy settings?
Also, what happens if you enable debug logging in FME Desktop before republishing to FME Server? The log should hopefully contain more information.
bruceharold
Forum|alt.badge.img+20
  • Dec 16, 2019 3:40 PM UTC
FME Server 2019.1.2
Thanks
I believe 2019.2 has retry logic in the AGOL reader/writer to help with this issue. If you can capture a detailed log like david suggests and open support call with Esri giving exact timings they can comment on 50X errors more.
  • Dec 16, 2019 3:52 PM UTC
150
This is our log:
ArcGIS Online Feature Service Writer: Encountered an unexpected error. The error code from the server was '504' and the message was: 'Your request has timed out.'. Details: ''151A fatal error has occurred. Check the logfile above for details152... Last line repeated 2 times ...1532019-12-16 13:35:36| 10.9| 0.0|ERROR |
bruceharold
  • Dec 16, 2019 4:08 PM UTC
150
This is our log:
OK tell Esri your org ID, the service and layer being written to and see if they know of any issue.
runneals
Forum|alt.badge.img+32
  • Dec 20, 2019 9:52 PM UTC
It's a known error produced by ArcGIS Online that esri knows about. Here's a list of things I would check...
1) Check your readers/writers to make sure they are updated.
2) Change the Features Per Request from the default of 1000 to 100 or 200, so then less features are sent per request, and it should perform better.
3) Contact esri support and ask to be added to the following bug (I know it only says 503 and 502, but 50x errors are all related. BUG-000123780 : Intermittent 503 and 502 errors with 'query' and 'applyEdits' requests to ArcGIS Online hosted feature service
Check out this thread for more... https://knowledge.safe.com/questions/84687/arcgis-online-readerwriter-error-code-503.html
