The steps to follow when extracting a feature layer from the attached screenshot polygon.
jeremiah567
I want to extract data within the masked polygon by using FME. Can you please guide me how it should be done. Which transformer to use?
Best answer by virtualcitymatt
Take a look at this article: it talks about how to use the clipper. This should be pretty comparable to your desired workflow: https://community.safe.com/s/article/example-using-the-clipper-transformer
virtualcitymatt
Forum|alt.badge.img+39
jeremiah567
  • April 12, 2023
I am yet to find a solution to the problems. Will update as soon as I find one.
