The ArcGIS FME keeps the old local IP,
  • Sep 24, 2014 7:10 AM UTC
  • 27 views
jamal
Forum|alt.badge.img+5
We have switched the local IP to real IP. It appears that the FME Servers still generating URLs with the Local IP.
What might be the issue here?
How to set the FME Server to generate URLs with the Real IP?
Thank you
Best
Jamal
  • Sep 24, 2014 9:30 AM UTC
Hi
I think you just need to change the URL pattern for each of the services using the Services page of the webui.
Documentation link here:
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#AdminGuide/changing_hostname_webserverport.htm
