Texturing LOD2 CitgyGML with 3DMesh file
  • Jun 20, 2019 10:32 AM UTC
  • 150 views
vignesh
Greetings,
I have built LOD2 CityGML from Shapefile and Point cloud XYZ data. Also the point cloud is converted into a 3D Mesh file. Available mesh data format of the mesh are *.obj, *3ds, *collada, *glTf.
Is it possible to texturize the extruded buildings using the Mesh?
Appreciate your time and suggestion.
Mesh:
LOD2 CityGML
jovitaatsafe
Forum|alt.badge.img+11
Hi @vignesh,
Are you still looking for an answer to this question? I'm not 100% sure as I'm more accustomed to working with image textures, but have you tried using an AppearanceExtractor on the Mesh and applying the appearance with the AppearanceSetter before writing out to CityGML?
There's an article Creating a Textured CityGML Model that might be helpful to take a look at perhaps. It includes a downloadable workspace template that you can explore. And Extract Layers from Traits and Swap Appearances may be another helpful example to see the AppearanceExtractor and setter in a workflow. Hope that helps!
