Text to Text Node
  • Feb 26, 2014 10:18 AM UTC
  • 10 replies
  • 71 views
I'm trying to convert a DGN file with text to a DGN file with text nodes. What do I have to do?
Any help would be appreciated.
  • Feb 26, 2014 11:26 AM UTC
Try the 2DPointReplacer (renamed VertexCreator in 2014).  This should generate a point at the text insertion point.
  • Feb 26, 2014 1:16 PM UTC
Thanks, but this is not what I'm looking for.
My export is a DGN with Text again.
fmelizard
Forum|alt.badge.img+22
  • Feb 26, 2014 1:45 PM UTC
Hoi Joost,
What do you mean by text nodes?
  • Feb 26, 2014 2:19 PM UTC
Hoi Itay,
This is a screenshot from MicroStation:
fmelizard
  • Feb 26, 2014 2:33 PM UTC
:) nice a picture pointing to ......well I found out a bit more and in FME terminology see:
http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#igds/Text_Nodes.htm
My guess is that you should map and aggregate the text (igds_text) to multi text (igds_multi_text)
gio
Forum|alt.badge.img+15
  • Feb 26, 2014 3:02 PM UTC
I assume that a textnod in DGN is like the autocad insertionpoint.?
Your DGN has text, then doesn't it have insertionpoints by default?
Im not savvy on Microstation as i use Autocad ( and my favorate Rhino3D...)
But on the fme site is this one:
http://fmepedia.safe.com/articles/FAQ/Text-Node-Creation
  • Feb 26, 2014 3:04 PM UTC
Are you making fun of me? :)
But I'm still not getting it (very surprising)
Tomorrow I will try again!
Thanks so far
fmelizard
  • Feb 26, 2014 7:36 PM UTC
Not really, I really dont have a clue what text nodes mean to you :) I do have an idea, but it makes it easier to understand the problem if we all talk about the same thing.
The link Gio is proposing looks promising....
  • Feb 28, 2014 10:18 AM UTC
Thanks for all the help.
It helped me in the right way. I think I'm close, but still not there.
The FMEpedia was a nice help, I used example number 2, but that one is much more advanced then I need. I've just got 150 text object that needs to be converted to text nodes. I'll let you all know when I'm done.
  • Feb 28, 2014 11:02 AM UTC
I've done it!
Thanks!!
