text in dwg file can't be affine transformed
  • Oct 31, 2013 6:28 AM UTC
  • 8 replies
  • 149 views
I   made an  affine  transformation on my dwg file .  in fme Data Inspector 2013 the transformed result is good .but When I opened  the  resulting  dwg file in  AutoCAD  2008,  I found  the  text  position  remained unchanged  , only  others  like  point ,line ect   is at the  correct  location. why ?
Can  any  one  help  me ? thanks  in  advance.
gio
Forum|alt.badge.img+15
  • Oct 31, 2013 11:57 AM UTC
I dont use acad 2008 anyore,
But 2010,2013 version display the text affined correctly with the rest of the objects.
gio
  • Oct 31, 2013 12:07 PM UTC
i tried more complex affines, still works fine and displays correctly in autocad.
bjarne
Forum|alt.badge.img+5
  • Oct 31, 2013 2:32 PM UTC
you should remove autocad_alignment_x and autocad_alignment_y, prior to the reprojection.
This problem is described in PR #48657 asking to improve CsmapReprojector functionality.
  • Nov 1, 2013 1:58 AM UTC
thank you Bjarne,Gio
I  removed autocad_alignment_x and autocad_alignment_y, prior to the  affiner  transformer ,but  the text  error  is still  here.
except  text , all  other  lines ,points,.blocks etc  are  transformed  to the  correct  position .  my  source features  position  is  about 1000  kilometers far  away  from the  destination  position.  why  the  texts  remained  unchanged?
gio
  • Nov 1, 2013 10:32 AM UTC
..hmm.
Maybe u can extract the textpointlocation in FME prior to the affine operation and then after the affineoperation reasign it to autocad text?
I cant test it as i have no Aucad 2008 alas.
geolucho
Participant
  • Participant
  • Nov 4, 2013 7:34 AM UTC
Hello,
tri to value following format attributes:
autocad_text_x_pos
autocad_text_y_pos
with AttributeReprojector transformer.
Though I don't have that problkem ...
  • Nov 12, 2013 7:03 AM UTC
I  used  acad 2013  and also I assigned value to the  autocad_text_x_pos and autocad_text_y_pos  withing  attributecreator and expressionevaluator ,but nothing  changed.
the text remained unchanged.
any help  appreciated.
ana
  • Dec 10, 2013 11:49 AM UTC
I Alice,
Did you solve you problem?
I have the same problem with text. I've tried AttributeReprojector, CsMapReprojector, Reprojector...
My text have Justify "midle center" and when I change to "Left" ( previous in the autocad), works.
Then I put again the Justify for all text to "mildle center" (again in the autocad)
This is enough for one file but I have 250!
There is another way??
thanks
