Text File Writer: is it possiblle to set the filename from an attirbute value?
davtorgh
Forum|alt.badge.img+11
Hi everyone,
this should be a simple thing to do, but I can't find how (or even it is not possible).
Thanks!
Best answer by ebygomm
Yes, you can set it in the Navigator panel
Capture
Forum|alt.badge.img+39
  • August 21, 2020
Capture
davtorgh
  • August 21, 2020
Capture
Thank you @ebygomm​ ,
very simple solution| :-) I usually use fanout to split the output into several files, it didn't occur to me to use it for one file only.
