Supports geolocation the new application for Android?
  • May 18, 2022 1:35 PM UTC
  • 47 views
danminneyatsaf
Forum|alt.badge.img+13
Hi @estudy000​ would you be able to specify which mobile application you're asking about here? FME AR or Data Express?
  • Jun 13, 2022 4:38 PM UTC
Both
danminneyatsaf
@estudy000​
In short, the answer is yes, both FME AR and FME Data Express allow for using geolocation on both platforms - iOS and Android!
There will be a pop-up requesting access to location on the device when the app is installed. Geolocation on AR means "geolocated model" which knows where it is supposed to be loaded and can be loaded either where it is supposed to be OR where the user is located ("here").
