Strip HTML From Text
  • Apr 3, 2017 6:57 PM UTC
  • 9 replies
  • 499 views
Is there a transformer for stripping HTML from text? I see the HTMLStripper, but it appears to replace HTML with XML. I want all HTML tags removed, including the <!DOCTYPE html>.
Thanks
Best answer by jdh
Using the StringReplacer as @erik_jan says, but with <[^>]*> instead should remove all opening and closing tags.
erik_jan
Forum|alt.badge.img+26
  • Apr 3, 2017 7:18 PM UTC
Could you use the StringReplacer transformer using regular expressions:
Find "<.*>" and replace with nothing.
This will replace all <anything inside> occurrences in the text.
jdh
Forum|alt.badge.img+41
  • Apr 3, 2017 7:27 PM UTC
That's a greedy expression and will replace everything from the first opening tag to the last closing tag.
jdh
  • Apr 3, 2017 7:30 PM UTC
erik_jan
  • Apr 3, 2017 7:36 PM UTC
Oops, you are right.
This expression is more selective: "<[a-z|0-9| !]*>"
  • Apr 3, 2017 7:39 PM UTC
I was able to strip the HTML tags with this little gem:
However, I couldn't remove the lines with only spaces or no content. I used another StringReplacer to remove the spaces, then a tester to see if the line was an "empty string". That worked.
Thanks
jdh
Except it doesn't match any tags with attributes, or closing tags for that matter
erik_jan
  • Apr 3, 2017 8:01 PM UTC
Okay, it is not complete. And I do like your solution: <[^>]*>
I guess my regex knowledge needs some extending.
jdh
  • Apr 3, 2017 8:07 PM UTC
There is a good explanation of lazy vs greedy at http://www.regular-expressions.info/repeat.html
The bonus is that it uses html tags as it's example.
jdh
  • Apr 3, 2017 8:21 PM UTC
Thanks
You may be able to use the XMLFormatter prior to stripping the html tags to remove extraneous whitespace and empty elements. Make sure to change Whitespace Handling to Remove excess whitespace.
