Start row parameter
  • May 2, 2016 1:43 PM UTC
  • 107 views
I'm a new FME user, so any help would be greatly appreciated. I'm using FME 2014. I have a workbench with just a reader and a writer. The reader is set to start reading at row 2. This works great until I save the workbench and go back in, and then it seems to reset to start reading at row 1. This has happened twice so I don't think it's just me? Can you point me in the right direction? Thanks!
  • May 2, 2016 2:35 PM UTC
One update: When I'm in workbench and I save the file, it still starts reading at row 2 as expected. But when I close the file it defaults back to row 1. Is there an option somewhere that resets when I close workbench and go back in? Thanks again!
mark2atsafe
Forum|alt.badge.img+59
That sounds like a bug to me, but one that Safe is likely to have fixed. My advice is to upgrade your FME to a newer version and try again. I would expect it to work correctly then. If not you should certainly contact your support representative (either at http://safe.com/support or your local reseller) and log a case about the problem.
  • May 2, 2016 8:29 PM UTC
Thank you! I'll see if I can upgrade to a newer version.
