SQL Server Error: "Unable to decrypt data"
  • Jun 14, 2024 8:26 AM UTC
  • 348 views
martinjaeger
Forum|alt.badge.img+7
In FME Form 2024.0.1.0 I got an error when trying to read data or schema with “Microsoft SQL Server Non-Spatial” Reader: “Unable to decrypt data”. On the same server, connection with SQL Server Management Studio works fine.
Does anybody know this problem or has a solution?
Regards, Martin
martinjaeger
  • Jun 14, 2024 9:47 AM UTC
I have two additional informations:
  • the problem doesn’t occur with JDBC, only with ADO
  • the problem exists only for one windows user, therefore we are checking user rights and policies
evieatsafe
Forum|alt.badge.img+28
  • Jun 18, 2024 9:36 PM UTC
Hi @martinjaeger, this sounds similar to something we’ve seen where registry keys were the cause of the error. (FMEFORM-31224) If you submit a support case we can help guide you through this process to see if this is the case or investigate further with you. Sorry for the inconvenience!
martinjaeger
  • Jul 2, 2024 11:37 AM UTC
I deleted the file c:\Users\[UserName]\AppData\Roaming\Safe Software\FME\fme_userconnection.data
This solved my problem. Then I was able to add new connections and to connect to the SQL Server database
